Macbook 2009 820-2530 - no spin-up
If you work close to 3/5V power supply, check for any knocked off component, or damaged trace.
Pay atention for enabling signals...
Q7221 is close too.
And it has few components connected on the opposite side; related with enable signal...
jpadie
Hi again
I'm getting only 22Ohm to ground on pin 1 of L7260. has anyone got an equivalent board they can test for me to see what's normal? injecting voltage there I get some high(ish) heat on the L3405 and C3452 pair. and some heat on the two inductors l3402 and l3403. I will remove C3452 in the morning to see what difference that would make, but I'd expect closer to zero ohms for a real short to ground.
jpadie
I'm really getting confused by this. I suspect it is in large part because the schematic does not line up at all with the boardview files I have. I'm using drawing number 051-7546 in case that helps anyone ?
on the boardview, the pin that has the low resistance is pin 1 of L7260. On the schematic, pin 1 is connected
directly to TPS51125 (labelled as U7201 on the schematic and U7200 on the boardview) to the P3v3s5_LL pin
indirectly via an RC pair R7264/C7264 to P3v3S5_VBST
and into Q7260.
the low resistance to ground remains there even when Q7260 AND the TPS51125 are removed.
On the boardview, pin 1 is connected to all sorts of things. So it looks like the pin numbers are inverted.
Is this is a known issue with the generally available boardview/schematic pairs? I'm feeling it is not worth the time to chase a rabbit down a hole when the map of the burrow is incorrect ...
jpadie
Harrumph ...
i have found a schematic that corresponds to the boardview now. i will trace from pin 1 of l7260 and see what i find before posting back again.
thanks
L7260 is a short in DC, like any other coil.
I suppose the low value is on L7260 pin2.
Lift one side of the coil and see where the low value remains...
jpadie
if course - as per the above, the short is on the side of pin 1. I've lifted so far the RTC, Q7940, U7200, L3405, U4800, C7291, C7290, Q4590, Q3450 and tested the resistors and other caps in the area. the low resistance remains.
Lifting resistor R7267 tells me that the problem is on the pin 1 side of that.
But nothing looks bad or burned on the board. No corrosion and, as I said, it was working fine until I 'fixed' the speaker connector just north of U7200. Evidently I've blown something downstream, but with 20Ohms it's unlikely to generate that much heat to be able to trace it.
When I'm next at the bench I will life U6200 just in case that is the culprit.
jpadie
removing U6620 increased the resistance to 50Ohm. may be worth removing U6630 as well. Perhaps I blew the audio amps?
jpadie
and removing U6620 and U6610 resolved the short. resistance to ground on PP5v_s3 is now 3.8k or so.
hopefully that resolves the power issue generally. I will have time to test properly this evening (fingers crossed)
