Macbook A1466 820-00165 25 AMps
Instafixx
PPBUS is 8.6V
Get MGasage
3v42 present
SMC_RESET_L present
PM_SLP_S4_L absent
U1950 voltages missing as well Pin 1 to 7.
Replaced U1950. Still the same
Check for pulse at PM_SLP_S4_L (at same time); it should stay high in fact.
If not, there is a problem with PCH...
If doesn't react at same time with PM_PWRBTN_L, PCH is suspect.
Just in case, check its RTC signals.
So i just checked the board is pulsing every 5 seconds.
almost all big coils. Even PM_SLP_S4_L.
I replaced R1275. Still the same.
Current draw on the PSU is also the same.
Yes both pulsing Pin 7 and 3 of U1950.
No shorts on any of the U8010-80.
Voltages are pulsing every 5 Seconds.
3v3_s5 Stable
Any history available?
Corrosion signs on the MLB?
Just in case, try to reflow PCH area, to eliminate eventually crap underneath.
