Macbook A1466 820-00165 PPBUS 0.5V
Instafixx
PP3v42 is ok.
PPBUS_G3H stuck at 0.5V.
Removed the fuse.
Pin 2 is 0.5V and Pin 1 is 1V.
Diode Mode Readings to Ground ( With Fuse Removed)
Pin 2 is 0.452
Pin 1 is 0.003.
Instafixx
Diode Mode Reading to Ground
Q7130
CHGR_UGATE 0.002
PPDCIN_G3H_CHGR 0.532
CHGR_LGATE 0.478
CHGR_PHASE IS 0.003
U7100
CHGR_AGATE 0.637
CHGR_DCIN 0.640
CHGR_ACIN 0.540
CHGR-VFRQ 0.497
CHGR_ICOMP 0.732
CHGR_CELL 0.144
CHGR_VCOMP IS 0.734
CHGR_VNEG 0.537
CHGR_AMON 0.737
SMBUS_SMC_5_G3_SDA IS 0.537
SMBUS_SMC_5_G3_SCL IS 0.537
Do you want more readings.
Instafixx
C7140 as broken. repalced it. Machine now switches on. I can use the mouse and input the password when it switches on the first time. Post that the keyboard and mouse stop working. The on/ff switch works though.
Very weird.
