Macbook A1466 820-00165
Instafixx
Device came in with intermittent shutdown and not charging issues.
Found R1955 /R1650 / R0620 all corroded. Replaced them. Now the shutdown issue is gone but the charging issue remains.
Device shows battery charging when charge connected but the percentage will not increase. Restart the machine and the battery percentage will increase drastically.
Remove the charger still get the BOLT charging sign.
Instafixx
SCL/SDA Didoe Mode 0.557
Voltages 3.4V
Resistance Across Pins of U7100
17/18 is 3.5 Ohms
27/28 is 20Ohms
