Macbook A1466 - No Power. No Magsafe
Instafixx
PPBUS 0V
PPDCIN 0V
DC Power Supply started beeping when connecting the charger.
Removed the Fuse.
PPVBAT_G3H_CHGR_REG diode mode reading is .145.
Removed R7150.
Short remains at PPVBAT
Injected 1V.
Q7130 getting mildly hot on the IR Camera.
Replaced Q7130 and R7150.
All readings are fine.
But still no voltage at PPBUS. No Magsafe Light.
PPDCIN is now 0.5V.
Instafixx
Even on PSU the issue persists.
PPDCIN_G3H_CHGR is shorted.
Injected 1V.
C7130 was getting hot.
Short Removed.
Now i get light and PPBUS is 2V.
i start checking around.
PPDCIN_G3H is short again.
PPBUS_G3h is also shorted
Replaced Q7130 again. No More shorts.
But the issue still persists.
Instafixx
Reflowed U7100. PPBUS now at 4V both sides. Getting Magsafe Light.
Went ahead and replaced U7100.
PPBUS dropped to 2V both side.
Replaced C7125 as well.
Instafixx
Q7130 was heating. PPDCIN_G3H_CHGR is short again.
Why is this happening.
Replaced the Q7130 again.
Its again heating.
Diode Mode Readings
CHGR_UGATE is 1.1
Rest all are okay.
Instafixx
Have replaced C7125. All Good Connection.
UGATE Pin connection to U7100 and Q7130 is good - verified.
What should i do?
Instafixx
I performed a MacOS restore and the wifi is gone now.
No wifi option while setting up.
No Wifi Option in the recovery menu.
Found PP3v3_WLAN shorted.
Diode mode to ground is .097
