Macbook A1706 820-00923
ipetro
The image is not displayed on the internal or external display.
The fans don't spin, the caps lock doesn't light up, the touchpad clicks
ipetro
L7030=13,08v\diod mode 0.436
L8410=0.012v\diod mode 0.778
LB700=0v\diod mode 0.129
L9400=2.7v\diod mode 0.335
L7660=3.35v\diod mode 0.322
L7600=5.13v\diod mode 0.387
L7700=1v\diod mode 0.123
L7900=1.2v\diod mode 0.165
L7960=0.95v\diod mode 0.016
L8050=1v\diod mode 0.008
L8000=1v\diod mode 0.010
L7270=1v\diod mode 0.002
L7220=0v\diod mode 0
L7210=0v\diod mode 0
L7410=0v\diod mode 0
L7420=0v\diod mode 0
L7430=0v\diod mode 0
L3500=0v\diod mode 0.121
Forget SMC bypass, you have almost all voltages, except VCORE.
However, Google knows something about SMC bypass; for the future.
Try known good BIOS.
ipetro
I replaced the BIOS chip from another identical board, no changes! could you give me your bios?
ipetro
To reset SMC and NVRAM you need a keyboard, but as I wrote earlier, the touchpad clicks but the caps lock does not light up green when pressed, which means the keyboard does not work.it's just stuck at 20v and 0.200-0.218a
As I said, forget SMC bypass.
I asked about it in my first reply, when I didn't know almost anything about your board.
ipetro
There are two options: bad T2 and bad CPU. And as I understand it, it’s impossible to check either one or the other?
