According to the owner, it didn’t turn on in the morning! I didn’t find any traces of flooding, everything looks good! I checked the display is working properly. battery is charged.
Resetting smc/pram did not help. Safe mode does not turn on. When you press command+R, the apple logo on the external monitor and the MacBook does not reboot cyclically. but the apple doesn't pass (
if you listened to the video in the post, then the sound there is one time the sound plays well and two times only the end of the sound! all the voltages seem to be there, the picture is there but cannot load
SMC bypass is a mode where several SMC features are disabled (sensors in particular), you disconnect all power, press power button, connect Magsafe and keep power button held for 5 to 10 seconds. Fans should go at max speed.
