Macbook A2141 820-01700 A
U7800 LDOs, SLPS2R and AWAKE voltages are exact comparing to the schematics, I noticed that C7020/3 Those are looking washed away but not shorted , should i go ahead and replaced them ? also U7000 Was replaced by a new chip , You think replacing it by another one reballed from a Donor would do better please advice otherwise everything else is looking ok to me .
You should check all secondary voltages, from pages 69-79.
If battery holds charge, PPBUS_G3H should not drop to 0V when USB meter restarts.
Also 3V3_G3H_RTC and PMIC LDOs must be stable.
Just a quick update, I am too sure if it's the battery or I was testing using a 87W charger , I went back to review the area of U7000 And I proceeded to replace R7061 , C7023 ,C7020 as well as U7000 , Now the device behavior while on the USB Amp Meter is staying without battery disconnected, but as soon as I connect the battery USB amp meter is going off and on. But it's not booting at all but the 20V is showing on the amp meter , I was not using the 96W charger Let me know anything please , Thank you.
