MacBook A2141 820-01700
iFix
I found chips but the position it's not exactly the same. Mine are 8600/87/88/89/91/92 and the new ones are 86/87/91/92/93/94. Will they work ?
iFix
What if I find chips taken out from the same spot, will I then need a programmer, and what kind of programmer is it?
iFix
Yes, I saw the P13. I have the JC main programmer, but I'll have to buy this one. Do I need any files from the old chips like Wifi, BT, Mac address...?
P13 will initialize the NAND according with its position on the specific Macbook model.
You can find several videos about how to use it on Internet.
iFix
I received the programmer, waiting for new NANDs, I'll update you with the results since I also have another A1990 4 NANDs config that I need to replace :)
iFix
Hi.
I'm back on this one. I received the SSD chips. 6 x 128GB TSB4228. In the package, they sent 6 chips of which one was from a different spot. I first tried to solder them as they were from the spots where they came from since the supplier advised us like that, but it didn't work. Then I took them out again, but this time I reprogrammed them with the P13 and for the first time the process of Revive went through and I get to the Lock sign as referred on the Wiki page. After I do the Revive it says the Apple Controller is Booted, but I cannot restore it, and even during the Revive process I don't get the Logo as normally should. I attached pictures of different variants of the process but I think it gets stuck on Exclusive Device Connection. Also, note that when I wanna reprogram the chips on P13 the only combinations that it shows are 1Tb and 512GB.
Any ideas would be appreciated. Thanks
iFix
When I try to restore it It says State Booted as shown on the uploaded picture A2141 SSD 4, but nothing happens just stays like that no picture not taking power more than 5v, and if I remove the restore cable that goes to the working Mac it's gonna try to boot gets 20v but stays 0.30a
