MacBook A2141 - Not charging
overshoot
I have that board 820-01700 that is not charging.
Laptop is turning on with charger plugged in.
It will also work on battery but will not charge the battery.
I am getting 20V with 0A drawn when battery is plugged in on all 4 ports.
However I got it to charge for a few seconds and then it stopped.
Battery level is detected by the system.
After inspected the board, I've found a blown cap on PPBUS_G3H near the ISL chip.
I am kind of at a lost on where to start diagnosing.
If board starts with no battery, CD3217 are working fine I assume.
So I am tempted to blame the ISL.
Shall I go ahead and replace that chip first or I am on the wrong path?
overshoot
Yes I did. I tested 2 different batteries and used my test mainboard which was able to charge the customer’s battery
overshoot
Those 2 lines are at .47V drop to ground.
Voltage with charger and battery plugged will oscillate between 1.5V and 1.7V for both lines.
When I reconnect the battery, the battery will start to charge and when the amperage reaches 3A or so, the charger will reset (USB-C meter switches off then on again) and seats at 20V 0.04A.
I went ahead and check the current sensing resistors. All check fine.
Then I went ahead and replace the ISL from the same board (donor) and nothing changed.
Since the charger reset itself, is it possible the issue is in the USB-C circuitry?
Did you test if battery is charging connecting the charger directly to the port?
Some USB-C meters restart if current goes over 3A.
BTW, use 96/140W charger; required for this model.
overshoot
What do you mean?
I’ve seen my usb-c meter resetting sometimes but it’s closer to 4-5 amps. And it should restart charging then which in this case it doesn’t.
I am indeed using a 96W charger.
