Macbook A2141 Not turning ON
Instafixx
PPBUS at 12.6V
PP2V5_NAND_SSD1 is 2.5V.
The Machine goes into DFU but gets stuck.
I get Mouse Click. AMP Meter at 20V.
ALL SSD Lines have diode mode readings of .400.
PP1V8_S5 and PP3v3_S5 are missing. ( Both Diode Mode Readings are fine)
Remove the FUSEs.
PPVBAT_G3H_CHGR_REG is .543
BUT PPBUS_G3H is .340 ( Seems odd to me)
Is there a minor short on PPBUS_G3H ?
HISTORY : We hade replaced all 6 NANDs about a month back.
Did you try now DFU restore, or just revive?
What error do you get?
Check for drop pulse at SSD voltages every 20-25 seconds.
Instafixx
I tried Revive first. it gets stuck halfway with no error for more than 10-15 minutes.
SSD voltage was stable for a good 30 seconds and more
Instafixx
Its been almost 30 Minutes. ITs stuck at Installing. No Apple Logo or Progress Bar on the Laptop. No Fan Spin Either
