Macbook A2179 820-01958
Instafixx
U7800 was heting up.
Replaced and device turns on.
But i get the Back Screen :Macbook Restarted because of a problem"
tried DFU and multiple software restores.
It sometimes restarts at the apple logo - sometimes after inputting password.
Fan goes high.
I disconnected all components one by one to rule out peripheral issue.
without LCD connected on an external display device worked - i got a Kernel Panic Message saying "Third party kernel was not allowing the machine to boot and that it was disabled"
Thermal camera shows nothing getting hot
Try new installation with just external screen connected.
You can also test the machine disconnecting only camera from T-CON board; keeping internal LCD connected.
PP1V8_PRIM_PCH diode to ground is 0.031
It should be .280 as per openboarddata.
Its connected to U4740 (thermal tripping).
PP1v8_PRIM_PCH goes through a lot of places including the CPU.
Will injecting voltage yield any good ?
