MacBook A2289 820-01987-a
iFix
Hi guys.
I have this A2289 with no power on state. The adapter is stuck at 5v 0.2-0.3a cycling. There was a bit of corrosion on D8450 pin 1 and C8495 pin 1(no stuff), which I cleaned and resoldered, and still no power. I checked the diode mode for all coils and with no issues all values are good. I replaced U3100 with an original chip from another board and it does the same. There's another type c controller but wanted to ask for ideas before I replace it also...
They are both 0v and no short there's a diode value. PP3V3_G3H_RTC - 0.363 and PPBUS_G3H - 0.365
P_IN - 5.12v
AUX_DET - 1.3v
SMC_RST_IN - Under the T2 shield need to remove it
VDDA - 2v
VDDP - 2v
CBC_ON - Under PMIC U7800 and under U7000
EN_MVR - 0v
A/BMON - both 0v
