Macbook A2289 820-01987
So 0.467 was in fact voltage, not diode mode reading.
Please, post end "V" to specify voltage reading.
Looks like you don't get PPBUS_G3H then.
Or you have a broken trace; check continuity from R6900...
Yes will do it from now on , it was 0.467V, See i am observing something very funny with this macbook, if i put it down for a day without connecting the USB amp meter then the next day i go back to it all diode mode reading of PPBUS_G3H is 0.388 And PPBUS_G3H is 12.18 V but the usb meter is still stuck on 5.22V 0.01 amp and 0watts
As soon as I unplug and replug the USB amp meter PPBUS_G3H voltages would drop to 0.406V and all the other power rails would be giving very low diode mode reading as well as PPBUS_G3H Let me check the continuity from R6900
Yeah, but you didn't specify missing PPBUS_G3H before.
U7000 can generate PPBUS_G3H with just 5V input.
Just check if you always get 5V at R7020.
Then post U7000 basic voltages; P_IN, AUX_DET, VDDA/P, SMC_RST_IN, EN_MVR, CBC_ON, A/BMON.
Check them when missing PPBUS_G3H too.
As I removed F7000 I am getting Stable 12.26V at C7050 , I have tested it more than 10 times to see if it would fluctuate but voltages remain the same , let me know what it is next please.
I replaced F7000, I did not have an exact donor but i got one from macbook Air A1466 , I measured the voltage i am indeed getting 12.26V stable but my amp meter still stuck at 5.22V and 0.001amp and 0.00 watts , so no 20V yet .
