Macbook A2337 820-02016 (Stuck at 12.3V)
Instafixx
PPBUS is 12.3V Stable
3.8V Present
3v3_s2 absent - no shorts.
3V3S2_EN is missing as well.
PP3v3_S2_UPC also missing.
Bad U8100 ?
Now Suddenly PPBUS is 2V
Removed Fuse. Still same 2V
Replaced both CD3217 and U5200. Still the same.
P_IN is 5V
AUX_DET is 1.2V
SMC_RST_IN is 0.1V
VDDA/P both 5V
EN_MVR 0V
AUX_OK is 0.1V
A/BMON both 0V
No Shorts on any of the rails
Again PPBUS has gone down 1V.
There is some issue which i think i am not able to figure out.
Please guide?
U5200 issue resolved with reflow.
U7700
PPVDD_PMU_LDO_PREREG is 0.1V
Can you help with the LDOs of U7700 and U8100 so that i can check them?
U7700
You should check U8100 first; is the master.
For the missing LDOs, check in diode mode and compare with good board.
