Macbook A2337 820-02016 (Stuck at 12.3V)
Instafixx
Is there any connection between U5200 and U8100.
i have replaced U5200 3 times.
After replacement PPBUS is 12.3V.
Then when i probe around U8100 to check and go back to check PPBUS it drops to 1V.
Instafixx
I have replaced U8100 but again PPBUS dropped to 1V.
Replacing U5200 again. Now for the 4th Time.
Something is shorting U5200 again and again. Please guide me what it is.
Instafixx
U8100 LDOs
MPMU_VREF_ADC is 0V
PP3V3_S2_UPC is 1V
PP1V2_S2 is 0.5V
PP3v8_AON_VDDMain 3.8V
PP1V5_VLDOINT_MPMU 1.5V
PP1V8_AON_MPMU is 1.8V
NO SHORTS.
U7700 LDOS
While checking i found
PP5V_BSTLQ_SPMU shorted to ground. OpenboardData shows diode reading to be 0V but i doubt it. Can you confirm ?
Instafixx
Solved the Short on PP5V_BSTLQ_SPMU.
But i am getting 1.5V on that line.
Now 3v3_s2 pulsing from 1V to 2.5V but still not stable.
Replaced U7700. Still its the same .
Instafixx
Tried Voltage injection method and removed the short.
Then found 1.5V on that line.
Then replaced U7700.
Still the same 1.5V.
Let me replace L7800 and get back.
