Macbook A2337 Amp Meter Rebooting
Instafixx
The CD321s and adjacent components have similar diode mode readings.
Diode Mode Reading
PP3v3_s2 is .330
PP1v25_s2 is .280
Instafixx
Both LDO's Diode mode readings are same. Since the master port (DFU) is rebooting the amp meter. Should we replace UF000?
There must be a problem on USB-C area.
Both ports must have the same behavior.
I don't see any UF400/500 LDO reading posted.
Also compare CC1/2 lines.
Instafixx
Diode Mode Readings to Ground
CF400 - .469
CF408 - .502
CF405 - .512
CF500 - .469
CF508 -.512
CF505 - .522
USBC0_CC1/2 -.590
USBC1_CC1/2 -.584
Instafixx
Injected 1V to check if anything was shirted. Nothing gets hot.
Its still the same
There is no short, just lower resistance than expected.
Injecting 1V into 0.280 doesn't help at all.
Reflash UF260, if you have correct dump.
Or replace it, if you can get one from same model board.
Make backup anyway.
Check diode mode readings on all available components surrounding CD3217 chips.
Also compare on the USB-C connector pins.
Instafixx
All seem fine. As per the openboarddata startup sequence mentioned.
ppvbus_usbc1 is pulsing from 0V to 5V because of the charging port reboot.
Anything there that you think we can try and replace ?
