Macbook A2338 820-02773 Backlight Issue
Instafixx
Device was water damaged. PP3v_s2 was shorted. Bad caps near the wifi ic. Removed and issue resolved. Now the device is having intermittent backlight issue.
When no backlight PPVOUT_LCDBKLT is 50V
When Yes backlight PPVOUT_LCDBKLT is 43V
It is random but I found that disconnecting and reconnecting the display connector brings back the backlight whenever it goes away.
Video connector was water damaged but was cleaned thoroughly . Should I change the small edp flex or the connector the lcd board ?
