Macbook A2338 820-02773 No Display
Instafixx
Device came in as Dead.
Thermal Scanning showed UP900 heating up. Replace it. Device turns on now. But no image and backlight.
Getting image on external display. Sensor Issue ruled out as LID Open/Close resulting in external display on/off.
I just checked PP3v3_s2 is 2.2V at LC710.
Removed LC710 its 3.3V at P3V3S2_SW.
Replaced UP900 just in case - still the same.
Check if all RC709-13 resistors have correct value.
Also check 3V3_S2 in diode mode; compare with good board.
Replaced UC710. Still no effect. Removed RD710 now 3V3_S2 is 3.3V.
Shockingly no line on RD710 is shorted thought.
Still no display
Both Pins of RP700 has 3.3V
But EDP_PANEL_DISCHARGE is 0V . Bad QP700
EDP_PANEL_1V8_EN present
With RD710 Removed
PP3v3_S2 is 2.5V - (No Shorts injected voltage too)
PP5V_CAM is 5V
PP5V_SW_LCD_CONN 5V
EDP_PANEL_1V8_EN 1.8V
I2C_CAM_1V8_SDA /SCL 1.8V
I2C_ALS_1V8_SCL / SDA 1.8V
I2C_MLB2JERRY_3V3_SCL/SDA 2.5V
"Removed RD710 now 3V3_S2 is 3.3V"
With RD710 Removed
PP3v3_S2 is 2.5V"
WithRD710 Removed.
With LCD Connected 3v3_s2 is 2.5V. (Goes upto 3.3V briefly for 1 Second.)
Without LCD Connected 3v3_S2 is 3.3V Stable.
Replaced UP701 as well. Just in case. Still no display
I am so confused with this device.
Now will LCD connected i am getting 3.3v Stable- but still no image/backlight.
Please help me out here
