After joining the 2 lines. The screen goes off when approached with a magnet with board alone on desk.
But it wont go to sleep when the lid goes down after putting the board back on the chasis.
On a wild goose chase all along.
The issue is with the the Connector of the Touchbar. JT710. When that is connected - the sensor stops working.
If not connecting that the Sensor works completely fine.
Touchbar Scenario:
JT700 Connected / JT710 Not Connected - No Touchbar Display. LID Sensor Works
JT700 Connected / JT710 Connected - No Touchbar Display. TouchBar Touch function working. LID Sensor Not Working
All diode mode readings of JT710 seem fine as per opneboarddata.
Changed the small bridge connector of the touchbar . Still the same
A lid signal goes to JT700 and shouldn't affect back to UR300.
Just in case, remove RT702 and make short pins 2 & 3 of QT700; or between RT706 and CT706.
