MacBook A3113 (820-03285) – Battery Detected and Charging, but Instant Shutdown When Charger Disconnected
Pumemule
Hi everyone,
I'm working on a MacBook A3113, logic board 820-03285, that suffered liquid damage.
I cleaned the motherboard, and the MacBook now powers on and works normally with the charger connected.
The issue:
  • The battery is detected correctly by macOS.
  • Battery percentage is displayed, and the system indicates charging.
  • The MacBook shuts down instantly (less than one second) when the charger is disconnected.
  • I've tested two different batteries with identical results.
  • No short to ground was found on PPVBAT_AON_CONN or PPBUS_AON.
Voltage measurements:
Rail / SignalCharger ConnectedBattery Only
PPVBAT_AON_CONN13.27 V0 V
PPBUS_AON13.27 V0v
PPVBAT_AON_CHGR_R13.27 V0v
PP3V8_AON3.8 V0 V
SYS_DETECT_L0 V0.14 V
CHGR_BGATE (Q5265 Pin 4)Initially 13 V, settles at 4.9 V0v
Additional checks:
  • Continuity between J5150 pin 19 and Q5265 pin 5 is good.
  • R5190 measures the same voltage on both sides (0 V with charger, approximately 0.48 V on battery only).
  • No short to ground on the main battery power rails.
  • Battery connector J5150 pins 19/20 measure 0 V in battery-only operation.
  • Two batteries tested, same behavior.
Has anyone experienced this issue on the 820-03285 board?
Any guidance would be appreciated.
Thanks!
