You must clean the corrosion and replace damaged components.
Remove U6100, clean its pads and ones from board; check traces continuity and resolder back the chip.
Check diode mode to ground on 3V3_SUS; w/ and w/o U6100 in place.
Do not reflash BIOS yet.
Only change U6100 if it causes short.
