macbook Air 2015 820-00165A
Hi
Got a no back-light unit
Backlight circuit looks good
R5117 completely burned out thou, cant attach it back as both points are also burned out.
Any tips how to attach the replacement?
Closer inspection revealed that the Q5158 also has damage on the CPU_THRMTRIP_3V3 line
Those have nothing to do with backlight...what voltage do you get on BKLT output? There is a great guide on the pinned posts from Louis btw
Lot of information on the forum.
Especially 3437 and 00165 Air boards; just use search function.
Rebuild CPU_THRMTRIP_3V3 trace from Q5158 to SMC area.
Then solder R5117 to that line and wire its other pad to nearest 3V42 point...
Are you measuring resistance with power applied??? I hope not as that's a good way to mess up your multimeter...if you have 8.6 you don't have any kind of short on PPBUS. Sounds like bad LED Driver to me. BKLT_EN resistors ok?
That was the case. I have learned something today :)
No short now
R7788 - 300koms
R7789 - 146 kOms
Looking fine
Will replace f7700 and investigate further
"PIN 2 according to the schematics, the other pin was 0v"
According to schematic, D7701 has two pins, A and K.
And is impossible to have 0V at same time with a voltage on these pins; unless diode is burnt!
Post diode mode readings on all conections of U7701; red probe to ground.
Also post BKL_PWM/EN voltages; LCD connected, of course...
ok
U7701
Pins
1 0.002
2 0.002
3 0.564
4 0.0
5 started burning - most likely I put the wrong probe on but cant say as I dropped it
disconnected from power and rechecked the f7700, will have to replace it again
Pin 4 is now in -1.8
Just thinking - was my mistake measuring it while powered on?
Do NOT measure diode mode with power applied! Replace F7700 and just replace the driver. Wasting time measuring when you?ll know right away if it?s the chip or not replacing it...
Hi again,
Replaced the U7701 as well as F7700, also changed D7701 as it was showing same voltage on both ends
now - still no backlight
U7701 readings
1 - GND 0
2 - GND 0
3 - 2.865
4 - 0.559
5 - 0.636
6 - 0.427
7 - 0.427
8 - 2.952
9 - 0
10 - 0
11 - 0.461
12 - 2.655
13 - 0? (not sure if its the right testpoint)
14 - 0.415
15 - 0
16 - 0.461
17 - 2.657
18 - 0.629
19 - 0.626
20 - 0
21 - 0.650
22 - 0.650
23 - 0.650
24 - GND 0
25 - 0.651
I hope something pops out for you :)
Also measured voltages on Q7706 while on with screen connected (picture present) - 0v on every point :/ so rechecked f7700 (gone again)
Replaced F7700 again and Q7706 readings as follow
1 - 8.01v
2 - 8.02v
3 - 2.63v (LCDBKLT_EN_DIV_L)
4 - 8.15v
5 - 8.15v
6 - 8.15v
Rechecked D7701, 8.15 v on both ends
Thanks for looking
Hi, thanks for the message
XW7720, all in order continuity present from pin 5 of U7701 and to D7701
U7701 voltages
3 - 2.84 V
4 - 2.57 V
11 - 5.12 V
14 - 3.34 V
Cheers
