macbook air 2018 A1932 strange problem
farfan14
i dont have history of this macbook, but now it boots up and shows folder with question mark,usb boot is disallow and i am trying to boot from internet recovery but it always shows me error -5010F (46)
i tried about 20 times, also tried 3 another wifi.
thanks in advance, i hope someone have experience about this problem
Can you post your 820-xxxxx board code.
Is an usual step when open a new thread.
Try DFU restore option.
It will erase internal SSD, if possible.
However, any initial data is almost gone.
Do not do it, if you still want to recover data.
Try revive option instead.
farfan14
yes the process finished without any error, and after process macbook turned on automaticaly and asking me to connect wifi and then same error.yes i selected "restore", not revive
Do a PRAM reset and try again with a wired connection. You'll need a USBC to USBA adapter and an Apple USB to LAN adapter. I have not verified if any other adapters work as the EFI needs to have drivers for it to work.
You could also try another WiFi network, make sure is has WPA security enabled.
