Macbook Air 5V 0.340A
scoman123
Hello, I will start this by saying I am VERY new to logic board repair, I know basics and learn best by doing but have found this difficult as I can't find my exact problem and just chunks of it which makes things hard to track for me.
It's a Macbook Air 2019 A2159 820-01598.
It was apperantly used for 3 months then randomly stopped, I was asked to repair it a year or so later as Apple wanted to charge too much.
It started off with 5v 0amps, I tracked down a problem with U7000, U9080 and U6903. When I replaced these I started getting 5v and 0.340A. I can't seem to get any further than this and have gotten a bit confused in the process, I can't remeber exactly what lead me to U7000 as this was about a month ago while waiting for new chips but U9080 was shorting to ground.
Voltages:
PPBUS_G3H: 5.02V
PP3v3_G3H: 0.00V
PP3v3_G3H_RTC: 0.00V
No short to ground that I can find anywhere, no visible damage, no liquid damage.
Any help is massivly appriciated.
"PPBUS_G3H: 5.02V"
Are you sure about this?
Isn't PPDCIN_G3H instead?
We need accurate information...
Post diode mode to ground readings on PPBUS_G3H (F7000), L6900 and L9080.
scoman123
Yes I get a specific and constant 5.02v on every point for PPBUS_G3H according to open board , specifically: F7000, R6700, F84000, CD770, CD771.
PPDCIN_G3H gives 5V at F3000, CD720, R7015, R7071.
For the resistance multimeter set at 2k ohms:
L6900: .381 & .389
L9080: .411 & .412
F7000: .466
What I have now noticed just by chance is that Q7040 (SIZ342DT) is producing a small amount of heat, not sure if this is a sign of a issue or just because the board was plugged in.
scoman123
Sorry, readings were all OL diode mode so thought the actual readings would be mroe helpful.
So yes, I think there is a short? This is where I'm still new to everything and to what to do next, If i put one probe on F7000 G3H and one on R7020 pin 2, PPDCIN_G3h_ChGR I get a short (a beep).
scoman123
Just rechecked everything to be sure, power supply not connected at all.
Diode mode readings are all "1 . " with red probe on a screw hole and black probe on point.
It will be next week sometime before I can change Q7030 & 40 because I have to order the components in.
