Macbook Air 820-00164-A no Cam after SSD upgrade
1phone.cl
Hi, i have a Macbook Air that the camera stopped working after a ssd drive change, i tried with smc and nvram restart and another 2 cameras and still doesn't work,
with a external usb camera works good
Volts J4002
Pin 12 5V
Pin 11 0.9V
Pin 10 0.9V
Pin 9 3.2V
Pin 8 3.2V
Pin 6 to 2 0V
Did you install some kind of patched macOS?
I saw this happened after unsuported macOS installed with OpenCore Legacy Patcher.
No, the Macos installed is the original Monterrey compatible with that model, i installed the older ssd and the camera still doesn´t work
Wait, do you mean an USB camaera works?
My fault, I supposed that internal camera works testing with an external USB macOS.
Check voltages and diode mode to ground on camera connector; w/ and w/o camera connected.
Compare values with similar board.
What error do you get, starting in diagnostic mode?
ALS works?
