Macbook air 820-3437 and 820-00164 PP5V_S5 missing PM_SLP_S4_L on both boards
Soji
I had to combine both logic boards issue in a thread, because they are some what similar. They have similar same issues, missing PM_SLP_S4.
PP5V_S5 is present
Signals that will make the PCH produce PM_SLP_S4_L are also present on both boards. 1.PPVRTC_G3H -3.3V
2. RTC_RESET_L 3.3V
3. PCH_SRTCRST_L 3.3V
4. PCH_INTVRMEN_L 3.3V
5. PCH_DSWVRMEN_L 3.3V
6. SYSCLK_CLK32K
7. PP3V3_S5 3.3V
8. PM_DSW_PWRGD 3.3V
9. PP3V3_SUS 3.3V
10. PM_BATLOW_L 3.3V
11. PM_RSMRST_L 3.3V.
Sometimes, PM_SLP_S4_L is intermittently present, but if I withdraw power and restore it, it goes missing again. I'd appreciate your input.
Please, do not mix the boards.
Same symptom doesn't imply the same cause.
When the PM_SLP_S4_L is high, which coils get voltage?
PM_SLP_S3_L goes high at same time?
PM_SLP_S4/3_L should pulse at same time.
Soji
Good day
You were right, I shouldn't have mixed board, I sincerely apologise for that. I also made a typo error, the first board was 820-3435-B.
For the macbook air 820-3435-B
-With Charger plugged in fan spins temporarily and stops.
-Triggered SMC_ONOFF_L , charger light changed from amber to green and back to amber, got a fan spin temporarily and PM_SLP_S4 went high temporarily. Both fan spin and PM_SLP_S4 occured simultaneously.
-As for the coils, I'm not sure what coils to check, pls can you specify for me what coils to check.
For the macbook air 820-00164-A
- With charger plugged in nothing happened
- Triggered SMC_ONOFF_L, there was no reaction at all
- I rechecked the those signals that will bring about PM_SLP_S4
PCH_INTVRMEN is 2.3V
PCH_DSWVRMEN was alsi 2.3V
PM_RSMRST_L was 3V they were not up to 3.3V
All other voltages was present and they were 3.3V
820-3435 board should restart two times, before stays on; like its 13" sister (3437).
Supposing that you've triggered SMC_ONOFF_L with R5115/16 pads (no keyboard connected), seems to have a problem with U5110, or its SMC_LSOC_RST_L input; check its level.
Open new thread for 00164 board.
Post there all the information mentioned above...
Soji
Understood, will open another thread for 820-00164
Th SMC_LSOC_RST_L is high at 3.2V, I will check U5110
Soji
Changed the u5110, the board comes on most of the times, let's say it comes on 7 times out of 10times, but during those times it does not come on if I trigger SMC_ONOFF_L it comes back on.
Soji
Apologies, I don't understand what you mean, pls can you rephrase, "Check R5127, traces and solders"??
Soji
R5127 is 0.4 ohm, which is approximately 0 ohm, there's good continuity from pin 2 of R5127 to pin 3 of u5110. Tried triggering SMC_ONOFF_L at R5115, there's fan spin and it stays on. But it does not stays on when charger plugged.
SMC_RESET_L MUST stay high when you press power button.
If drops but SMC_LSOC_RST_L stays high (no drop pulse at all), then the problem is around U5110.
Soji
Good day 2informaticos
Still on this system
I changed the u5110.
It worked for a while and went back to where we started from.
If I trigger R5116/R5115 or R5101 the fan will just spin temporarily and stop.
