Macbook Air A1932 820-01521-A No boot, 20V it goes to 0.45A then power cycling
L7030 is not in the same position as old boards.
Don't use it as refference, unless you find short to ground there.
PACh
tried to do DFU many times, the step 4 takes a longtime after that it goes to the lockpad icon with a warning at the botton saying the system has not booted or something like that and the system needs to be repaired if I try to repair it fails saying that in this state it cannot be repaired so I do DFU again and happens the same...
PACh
Desoldering the chip I lost the 20ohm resistor on the left side R4773 (SPI_SOCROM_MISO Line), I dont have a 20ohm resistor I got a 22ohm same specs, can I use it?
PACh
tried all and nothing worked, I think I will just mark it as no fix... Thank you for your help
