Macbook Air A1932 No display on external and internal with battery
Hi
Macbook Air 820-01521-2 has no display with battery. i have checked with different battery also but got same response. i am getting display on external and internal both without battery.
there is no liquid split sign on board or damaged component. Also checked with two different good screens.
USB meter shows 1-2 Amp when plug in with battery. it seems, it try to turn on but soon goes to 0 Amp and start taking heavy current(1.5 Amp approx.) looks like charging battery. Tried PRAM reset.
Also not able to login the device. it get stuck at login screen after entering the password and stays at login screen for hours. after that start rebooting at apple logo ion every 5 sec.
What could be the problem? i have no idea where to start.
Thanks
Hi
I have tried Revive and Restore both in DFU, After finish line each time i got the second image. System not booting at all. nothing on screen.
But when i unplug the battery and booted with charger only , ?mark was there on screen.
Something similar happened to me with a machine damaged because of liquid spill on the audio board.
In my case, I couldn't even complete DFU.
But didn't note the battery issue.
Inspect audio flex and board for liquid signs (both sides).
I have checked each and every single component on board, there is no liquid damage, rusted or loose soldering component. device shows display without battery and also acting with Command+R going for recovery.
Check exact resistance over C7020/23.
Try to start in SMC bypass mode, with both charger and battery connected.
Also check SMC_DCIN/BMON_ISENSE levels.
Tried SMC bypass mode nothing happened.
Diode mode values on C7020- .455V on both ends and C7023- .0545V.
SMC_DCIN_ISENSE-0V.
SMC_BMON_ISENSE- 0V.
First of all, Thanks Vali for your help and guidance.
there is no external video or USB activity with battery connected.
These are the CPU voltages which i check with battery connected and without battery, didn't found major difference.
PPVCCGT_S0_CPU--0V
PPVCC_S0_CPU-- 1.132V (without battery PPVCC_S0_CPU-- 0.712V)
PPVCCSA_S0_CPU--0.751V
PPVCCIO_S0_CPU--0.964V
PP1V2_S3--1.2V
PP0V6_S0_DDRVT-- 0.6V present
Connect both charger and battery,
Then monitor PPBUS_G3H; it should slowly increase, if battery is really charging.
initially PPBUS_G3H was 12.72 and then suddenly jumped to 12.93V. tried 2-3 time but jumping directly from 12.68V to 12.93V and further no increase in PPBUS_G3H.
