MacBook Air A2337, 820-02016
MarcinRdm
Hello Everyone,
One of my customers brought me a macbook air A2337 , probably board number 820-02016 after contact with liquid . He was in another service. When I plugged it in I can see that it stays around 5.090V and amp goes up to between 0.09 and 0.14. And it is on a loop like this. I can't find the Boardview.
Check for short on all big coils.
Compare readings with good board.
Also check if U7700 and U8100 deliver some voltages.
MarcinRdm
Unfortunately, I don't have the same motherboard.
L5800 - 22M oHM
L5820 - 7M OHM
L5840 - 7M OHM
LP800 - 2860K OHM
L5230 - 250K OHM
LC320 - 170K OHM
Should I restore the F5200 before checking the u7700 and u8100 ?
Of course, PPBUS_AON must be present.
BTW, use diode mode for checking on the coils.
Switch to ohm mode only for low values; usually under 0.005-0.010 readings (diode mode).
MarcinRdm
Big coils are ok.
PP3V8_AON_VDDMAIN 3.8v
PP1V5_VLDOINT_MPMU 1.5v
PP5V_BSTLQ_MPMU 5v
P3V8AON_IMEAS 0.03v
P3V3S2_PWR_EN_MPMU pulsing to 1.1v
PVDD1_PWR_EN pulsing to 1.1v
P3V8AON_LPM 0v
PMU_RESET_L pulsing to 0.6v
BUCK4_LX0 PP1V06_S2SW_DRAM pulsing to 0.6v
PP0V764_S1_SRAM pulsing to 0.6v
PP0V72_S2_VDD_LOW pulsing to 0.5v
PP1V25_S2 pulsing to 0.9v
PPVDD_PMU_LDO_PREREG pulsing to 1v
MarcinRdm
PP3V8_AON_VDDMAIN - 3.8v
PP1V5_VLDOINT_MPMU - 1.5v
PP1V2_S2 - pulsing to 0.8v
PP3V3_S2_UPC - pulsing to 2v
PP1V8_AON_MPMU - 1.8v
You can see that the u8100 corner is heating up.
Check diode mode to ground on the small coils around U7700 and U8100.
Also check if any get voltage pulse (if not shorted).
MarcinRdm
I checked all:
L8120 - diode-mode: 0.01 - pulsing to 0.5v
L8121 - diode-mode: 0.01 - pulsing to 0.5v
L8271 - diode-mode: 0.150 - pulsing to 0.5v
L8270 - diode-mode: 0.150 - pulsing to 0.5v
L82B1 - diode-mode: 0.05 - pulsing to 0.5v
L82B0 - diode-mode: 0.05 - pulsing to 0.5V
L8100 - diode-mode: 0.1 - pulsing to 0.5v
L8101 - diode-mode: 0.01 - pulsing to 0.5v
L8102 - diode-mode: 0.01 - pulsing to 0.5v
L8112 - diode-mode: 0.01 - 0v
L8111 - diode-mode: 0.01 - 0v
L8110 - diode-mode: 0.1 - 0v
L8280 - diode-mode: 0.05 - pulsing to 0.5v
L8281 - diode-mode: 0.05 - pulsing to 0.5v
L8290 - diode-mode: 0.18 - pulsing to 0.5v
L84E0 - diode-mode: 0.3 - pulsing to 0.9v
L8230 - diode-mode: 0.5 - 0V
L22A0 - diode-mode: 0.1 - pulsing to 0.5V
L7741 - diode-mode: 0.03 - pulsing to 0.8v
L7740 - diode-mode: 0.03 - pulsing to 0.8v
L7750 - diode-mode: 0.2 - pulsing to 0.5v
L77C0 - diode-mode: 0.25 - pulsing to 0.8v
L7760 - diode-mode: 0.3 - pulsing to 0.6v
Can you catch voltage pulse on the big coils?
You may have problems with U7700, or U8100; should change to discard.
