Macbook Air A2337 820-02899
Instafixx
Charges with only 1 CC Port. (Using 820-02016 Schematics)
UF400 corresponding port wont charge. UF400 visibly burned.
Replaced UF400 and UF500 Both. Still the same.
When doing thermal scanning and plugged in on UF500 corresponding port - a Coil and a 8 Pin ic heating up. The same flashes when UF400 is plugged in. (Image attached).
Due to lack of schematics i cannot move further. There is no short on any pin .
UF000 below the shield also heats up.
I cannot find the 8 Pin component anywhere on 820-02016 board.
MLB charges and boot through UF500 port?
What shows power meter connected to UF400 port?
Can you read top marking code of the that chip?
