MacBook Air A2337 (M1, 2020) No Backlight
ronaldo
No liquid damage or visible physical damage. Customer initially stated it suddenly no display.
All the diode measurements on the Backlight power circuity matches a good board.
  • Replaced UP800 (backlight boost IC) twice, also reflowed
  • Replaced DP800
  • Replaced QP800 (backlight power switch MOSFET)
  • Replaced UD050
  • Tested with a known-good display – still no backlight
  • No corrosion or mechanical damage on board
Power Line and Signal Measurements:
Signal / ComponentVoltageNotes
FL800 (backlight fuse)OK, passingFuse is intact
PPVIN_LCDBKLT_R12.0VInput to UP800
PPVIN_LCDBKLT_Q12.0VOutput of QP800 (after gate forced low)
PP5V_S25.18VPresent
PP3V3_S53.28VPresent
LCDBKLT_EN_L (QP800 gate)11.93VToo high, not turning on QP800
BKLT_SD11.93VOn good board, reads ~5.5V
BL_PWR_EN1.80VReaches UP800 pin 17 through RP842
RP8420Ω, 1.80V both sidesConfirmed good
LCDBKLT_FB (UP800 pin 2)12.0VToo high, expected ~1.2V
LCDBKLT_SW (UP800 pin 1)0VNo switching activity
LP800 (inductor)12VReceives power after QP800 forced on
DisplayKnown-good testedStill no backlight
ronaldo
I have done revive and restore and still no backlight. I have check everything again and compared against a good working board the the measurements in diode mode are correct. The only issue I found is:
LCDBKLT_EN_L (QP800 gate) 11.93V Too high, not turning on QP800 - On a working board it is normally ~6V.
Do you have any idea on how to proceed from here?
Thanks
ronaldo
I have checked another LB and BKLT_SD is 5.58V, which is pulling the voltage on the gate of QP800 low and backlight turns on.
On my faulty LB the voltage on BKLT_SD I s 11.58V.
