No liquid damage or visible physical damage. Customer initially stated it suddenly no display.
All the diode measurements on the Backlight power circuity matches a good board.
- Replaced UP800 (backlight boost IC) twice, also reflowed
- Replaced DP800
- Replaced QP800 (backlight power switch MOSFET)
- Replaced UD050
- Tested with a known-good display – still no backlight
- No corrosion or mechanical damage on board
Signal / Component | Voltage | Notes |
FL800 (backlight fuse) | OK, passing | Fuse is intact |
PPVIN_LCDBKLT_R | 12.0V | Input to UP800 |
PPVIN_LCDBKLT_Q | 12.0V | Output of QP800 (after gate forced low) |
PP5V_S2 | 5.18V | Present |
PP3V3_S5 | 3.28V | Present |
LCDBKLT_EN_L (QP800 gate) | 11.93V | Too high, not turning on QP800 |
BKLT_SD | 11.93V | On good board, reads ~5.5V |
BL_PWR_EN | 1.80V | Reaches UP800 pin 17 through RP842 |
RP842 | 0Ω, 1.80V both sides | Confirmed good |
LCDBKLT_FB (UP800 pin 2) | 12.0V | Too high, expected ~1.2V |
LCDBKLT_SW (UP800 pin 1) | 0V | No switching activity |
LP800 (inductor) | 12V | Receives power after QP800 forced on |
Display | Known-good tested | Still no backlight |
