Macbook Air A2681- 820-02536 - 5V 0.03A
ronaldo
I need some help, please.
The Mac has no signs of life. There is no liquid and no short anywhere on the board.
All the coils measurements in diode mode are matching with the measurements on the FlexBV.
I've tried to connect to another Mac, but it won't recognise it.
Both USB-C ports are getting 5v and 0.0310A
PP3V3_UPC1_LDO - 3.44V
PP3V3_S2_LDO - 0V
PP1V5_UPC1_LDO_CORE - 1.57V
Thanks
Just in case, I've replaced the U5200 - RAA489900. Replaced by the ISL9240 the pins listed and VDDIO voltage in schematics are the same.
But same as before. No changes in the voltages.
Not sure if ordinary ISL9240 works here.
That one expects 1.25V aprox on AUX_DET.
Your board works with 0.85V there; valid for 5V input.
Remove F5200 and check C5252 voltage.
I've checked all the components in that area and everything seems fine.
All measurements in diode mode match flexbv.
Only CHGR_GATE_Q1_R which on flexbv is 0.650 and on my board is 0.901. But I don't think this is a problem.
Please, open new thread with your problem.
Similar symptom doesn't imply the same solution.
