Hello there,
I could use some advise / tips & tricks / do's & don'ts / confirmation with following:
I have an A1398 with no backlight, the LCD works properly. The motherboard is ok, a spare screen lights up as usual.
The probable cause is a short under the connector at the display side. I spotted corrosion on the connector. I assume the user spilled too much cleaner on the screen in the assumption she/he could wipe off the staingate issue...
There is quite some corrosion on pins 1-5 being PPVOUT LCDBKLT, I2C BKLT SCL and SDA, so it is logical this is the cause.
There is a cap underneath the LCD PCB - what should this measure?
How do I repair this in the most safe way? I thought of following:
-Put a heat buffer below LCD print (alu-foil or so)
-Pre-heat to max 60 degrees Celsius
-Remove connector with wide soldering pin
-Clean residue with alcohol
-Solder new connector
-How do you remove the flux (standard Amtech) that gets in the connector while soldering???
-Measure for shorts
-Give it a try
Any experiences with this kind of issue would be very welcome because it is either a fix of 10 or 300 € if I screw up...
Best regards,
Stijn
-Measure for shorts
-Give it a try
Best regards,
Stijn
