MacBook Pro 2012 15 inch A1398 No power button
zehourii
A customer sent in his MacBook for repair. No water damage at all. resistor R5710 was not showing any continuity, I replaced the pin and it shows continuity. however, there's still no power button functionality.
Note- the keyboard is now stuck in caps for some reason :/
Do you have 820-3332 board there?
Check SMC_ONOFF_L and WS_KBD_ONOFF_L when you press power button.
Test using R5015/16 pads instead of power button.
If R5710 was corroded, remove C5710, which can be affected too.
