Hello guys , please I need your help here ... the 2016 15 inch Touch Bar... has no sound , but the sound isn?t grayed out , replaced speakers no changes , I can adjust the volume but no output even from the headphones
On the first post you wrote that changed out the speakers but did not solve the issue - can you please tell a whole story? So which speakers did work and what did you do to get them work again?
thanks in advance ?
ZAKLINTOWN sorry for my late response.. Thing is , the speakers that were installed apparently were not good , also I was a bit confused when the earphones wouldn't work either , but I figured I had to manually flip the output to headphones before it worked . As for the speakers , I had to changer them again . removing the spears its quite an issue to , cus there's a higher chance of damaging them , in the process
