MacBook pro 820-00239 power issue
EZBoard
hello,
i am new to this forum.
my name is Amir and i owe a electric repair shop in Israel.
i am new to MacBook repairs and have lot of knowledge to complete.
as for now i have a MacBook pro model 820-00239 that wont start.
the customer probably connected 3rd party charger and now it wont power at all.
as for start i checked for blown component under my microscope and found nothing.
when i connect the charger to the left side, both take 5v.
when i connect the charger to the right side i have 0V on both.
can you please guide me were to check?
Check diode mode to ground on CC1/2 pins of CD3215 chips from right side; compare readings with left side.
Do the same for LDO power rails of these chips; each one has 4 LDOs, consult schematic.
EZBoard
ub300[V]ub3100 [V]ub400 [V]ub3200 [V]
CC10.50.590.0020.6
CC20.0010.580.0010.6
PP1V8 LDO (PIN2)0.470.470.0020.47
PP3V3 LDO (PIN12,53)0.0210.490.0090.49
PP1V1 LDO (PIN 35)0.480.490.4850.49
PP1v8 LDOA (PIN 75)0.50.50.50.5
EZBoard
ok, thanks
parts are not availble here....
i need to order from other country and it takes time.
in such cases, from your knowledge, do you think it will be enough? of maybe usually other componnent need to be changed?
i am asking so i will order it together and save time
This is not an exact science.
Even replacement CD3215 can be bad (usual from chinese sellers) and you can waste time then, searching for another (inexistent) problem.
EZBoard
can you, please, guide me were i can buy them?
i tried to order from your store, but you have only one in stock...
Is not my store!
As recently posted in other thread, I prefer "board wings" to get original chips.
Reading all the threads you can get valuable information.
Take notes from each post which think can help you in the future.
EZBoard
so,
i got new CD3215 from beetstech.com
when i disordered the old one i pulled out lot of pads from the board because of the glue.
i fixed them all and soldered the new one, but still i have 5V.
can you please guide me what how to proceed..
You must be sure CD3215 area real good and correctly soldered.
Do you get 1V1 LDO for all them?
NO, I mean 1V1 LDO.
There are also 1V8 and 3V3 LDO rails.
You should be able to detect these lines by yourself, without writing entire names; 4 (four) on each CD3215 chip.
