MacBook Pro 820-01949 2020 with no internal display
sekidata
This A2251 MacBook Pro with mild liquid damage (USB-C area) is working fine on external display but does not recognize the internal LCD. I tried several displays and flex cables, and there is no backlight and no display. The internal does not show up in Settings>Displays, only the camera is recognized.
PP5V_S0SW_LCD is 0V except briefly during the chime (5.1V).
EDP_PANEL_PWR_EN is 0V except briefly during the chime (3.3V).
DP_INT_HPD is 0V except briefly during the chime (3.3V).
What would you check before blaming the EDP portion of the CPU?
sekidata
Just noticed that when the external display is unplugged, I do get steady values on PP5V_S0SW_LCD, EDP_PANEL_PWR_EN, DP_INT_HPD but no display whatsoever.
If DP_INT_HPD and 3V3/5V_S0SW_LCD stay high, then internal LCD is recognized by PCH.
You should check diode mode to ground on J8500 EDP data lines.
