Ictc
Got this laptop with little liquid damage spot around ISL that only prevented power up without battery connected and a shorted cap on the flash drive that prevented the drive to be recognized at boot. Fixing those problems, the machine powers up and boot but still without backlight. I of course cansee the image on the display if I put the light on the apple logo.
I did some measurments and got:
PPVOUT_S0_LCDBKLT = 54v
PP5VR3V3_SW_LCD = 5 volt
I than connected the only retina dispaly I have in house wich is a 13" in stead of the 15" just to give a shot.
This 13" model has the same eDP pinout of the 15" and I tought it shoulded work but in stead of having the backlight on as it is with the 13" inch motherboard, I still getting 54v on PPVOUT_S0_LCDBKLT and that's strange because on the 13", this value goes around 40V once backlight is working.
So far I can't really say that the screen backlight is damaged. Measuring in diode mode between ground and PPVOUT_S0_LCDBKLT I get nothing on both the displays and may be this measurement has no real reason to be done.
Is it normal that the display partially working on a known good machine doesn not on this other one? May be as a different inches model it is normal not to work on a different motherboard.
What else should I check just to be sure the problem is only with the screen backlight and not the logicboard?
