MacBook Pro A1502 820-3476-A 2014 - NO DISPLAY
Bockas
CHGR_Phase and PPDCIN_G3H_CHGR is shorted on q7130 on all 3 that i have
2PPDCIN_G3H_CHGR when i measure with q7130 removed voltage drop is 0.574
7CHGR_PHASE voltage drope wthout q7130 is 0.410
I replaced u7100 and q7155 and removed q7130, didn't turn on board yet bcs i'm not sure if q7130 is shorted or not
Bockas
READINGS ON BOARD WITH Q7130 OFF BOARD:
2PPDCIN_G3H_CHGR 0.590
7CHGR_PHASE grows from 0.100 to 0.420 steady
Bockas
I will post measurments on board, q7155 was shorted, after swapping it device is telling to plug the charger for the first time.
On
1PPVBAT_G3H_CHGR_R - steady 20 V
5PPVBAT_G3H_CONN - withouth battery no reading
Reading on board when q7130 off board
Removed q7155
1PPVBAT_G3H_CHGR_R 0.425V drop
4CHGR_BGATE 0.625, when you swap leads its slowly growing from 0,600,7,8,9 growing whole time
on q7100 pin 3
3CHGR_ACIN is shorted i puted bad chipšp right now obviusly
Please, check what I said and do not waste time with Q7155.
If you like so much to use lab PSU (which I don't recommend at all in this case), at least set it to 15-16V, instead of 20V.
Bockas
q7130 is shorted on leads
2PPDCIN_G3H_CHGR
7CHGR_PHASE
itsshort on all 3 of them did i blew up all of them?
I said to change Q7130 and U7100 at same time.
Also said to verify something more, before apply power.
Don't forget about power supply and original charger.
Bockas
I replaced what you said, q7130 didnt blow yet and when it blows device will work, now its short circuit somewhere but nothing even close to 0 ohm, what to do next i replaced u7100 and q7130 tested all leads all over chip is 0.300 or more no short
A missing voltage doesn't mean short.
Where did you find short???
Did you check what I said about U7100 pins?
Also post basic U7100 voltages; pins 1, 2, 3, 9, 12, 13, 14, 15, 17, 19, 20, 27.
Any reason to quote an entire post visible few centimeters above?
Please maintain forum aesthetic.
The short on D7105, which pin to ground?
Can be U7100, or C7105 problem.
I was expecting to get voltage readings also...
Bockas
I replaced D7105 that diode was problem after replacing device is charging and working normal on battery.
Device works normal and out of the blue screen starts to flicker sometimes, I reflowed connector inside the screen and I didn't get that problem again for now, I tried to post the picture but file is to large.
Any known issue when screen is flickering? On HDMI output is normal so I suppose it is screen problem.
