Macbook Pro A1706 SSD not Detected.
arshees
Need help with a 820-00239 board ssd not detected. Minor liquid damage seen but cleaned and looks fine. Looking around videos on the net found something I need confirmation with before I proceed. Checking in diode mode L9340 PIN1 - 0.036 PIN2 – 0.036. L9341 PIN1 – 0.036 PIN2 – 0.036. Is this short. Should I remove the coils and check for short?
arshees
Removed L9341. Readings now L9340 PIN1 - 0.299 PIN2 – 0.299. L9341 PIN1 – 0.036 PIN2 – 0.299. Can I try injecting voltage. How many volts and max amp?
