Macbook Pro A1708 PPBUS Short
Instafixx
PPBUS is short. Diode Mode is 0.007
Fuse is already removed.
L7410/20/30 is also 0.007.
Someone already injected voltages before.
Can it be salvaged?
Remove U7410/20/30, one by one.
Check when short disappears from PPBUS_G3H; replace corresponding chip.
Instafixx
Removed U7410 .PPBUS is no longer shorted.
But the Coils L7410/20/30 are still the same reading.
007 is the expected reading on these coils.
Replace U7410 and give it a try.
CPU may be already damaged by overvoltage; nothing to lose.
Instafixx
U7410 replaced.
PPBUS is no longer shorted but not getting any voltage on the Fuse Pads without the Fuse and amp meter wont turn on.
Previously was getting 7V and amp meter wont turn on.
Instafixx
I am checking without the Fuse. The machine came in with fuse missing.
No voltage and amp meter wont turn on
USB-C charger was recognized before you've touched U7410?
In such case, the heat applied on the board affected something else.
Instafixx
USBC_XA_CC1_CONN IS 2.78
USBC_XB_CC1_CONN IS 2.78
USBC_XA_XX1_CONN IS 2.78
These diode mode readings are very high. These should be 0.700 as per openboarddata.
Instafixx
All 4 resistors Ohms value across pins are same as a good working board.
Found PP3V3_UPC_XA_LDO to be OL.
Instafixx
Both U3100 and U3200 has bad solders. Re-did that.
All readings are back to normal.
AMP Meter turns on as well.
But the port corresponding to U3200 - the amp meter reboots every 5 seconds.
