Macbook Pro A1990 - No image or backlight - 820-01814
Roccolade
Hey!
I got this Macbook I’m working on. A Macbook Pro A1990 (820-01814) from 2018. It has no image – or backlight for that matter.
No history of liquid spills or anything. It's fully functional on external monitor - and the webcam works.. But it doesn't seem like the internal display is even detected in the settings.
The backlight has been lighting up a few times when entering recovery-mode.
I tested the panel on another Macbook, and the display worked perfectly. So, I know it’s well and working.
I get 0 volts on PPVOUT_S0_LCDBKLT. Tried diode-mode on PPVOUT_S0_LCDBKLT and got a reading of about 1950. I’m not I entirely sure what that tells me.
I really can’t figure out what the problem is. Can’t seem to find any defect components or anything.
All the best
-R
Check presence of 3V3_S0SW_LCD and DP_INT_HPD, when LCD is connected.
Don't waste time searching for backlight, if no image yet.
For diode mode readings, there is big difference.
That points to damaged U9850; change it.
Be sure no corrosion sign on that side of J8500.
