Hello, community!
I need help, please.
I have a MacBook Pro A2289 TouchBar that initially had liquid damage on both sides of the board around U3200/U3100.
I've reflowed the area and then cleaned on U.S cleaning.
Currently, the motherboard (820-01987) partially supports the 20V load.
The 2 charge ports are in 0.5A unstable, and are close to 10W but always drop down to approximately 1W unstable.
The trackpad reacts to the click.
Tried DFU mode and it doesn't enter in DFU mode.
Testing the voltages I'm wondering if you could help me find where the problem is coming from?
_________________________________________________________
L7030 : 12,60V
L7690 : 3,3V
L7670 : 5,12V
L8410: 0V (backlight coil)
L8100 : 1,2V PP1V2_S3
L8102 : 0,959V PPVCCIO_S0_CPU
L7702 : 0V PPVCCEDRAM_S0_CPU
L7270 : 1,021V PPVCCSA_S0_CPU
L7210 : 0,81V PPVCC_S0_CPU
L7220 : 0,81V PPVCC_S0_CPU
L7410 : 0V PPVCCGT_S0_CPU
L7420 : 0V PPVCCGT_S0_CPU
PP3V3_S5 - 3.3v present for 10 secs and then 0v
PP1V8_S5 - 1.8v present for 10 secs and then 0v
PPVPCORE_S5 - 1.06v present for 10 secs and then 0v
PP1V_PRIM (PCH POWER) - 1.06v present for 10 secs and then 0v
PP1V8_S3 - 0
PP1V2_S3 - 1.20v present for 10 secs and then 0v
PP1V_S3 - 1v present for 10 secs and then 0v
PP1v8_AWAKE: 1.8v
PPVDDCPU_AWAKE: 0.54v
PPVDDCPUSRAM_AWAKE: 0.8v
PP3V3_AWAKE: 3.3v
PP1V2_AWAKE: 1.2
PP1V8_SLPS2R: 1.8
PP1V1_SLPS2R: 1.1v
__________________________________________________________
Do you have a solution?
thank you in advance for your help
L7030 : 12,60V
L7690 : 3,3V
L7670 : 5,12V
PP1V8_S3 - 0
PP1v8_AWAKE: 1.8v
PP3V3_AWAKE: 3.3v
PP1V2_AWAKE: 1.2
PP1V8_SLPS2R: 1.8
PP1V1_SLPS2R: 1.1v
