macfix_hh_25
Hi everyone,
I have a MacBook Pro A1398 15" (Board 820-3662-03) in the shop for repair.
The MacBook powers on fine when connected via MagSafe. It initially came in with a "battery not charging" issue, and if you disconnected the power adapter, the machine would die instantly.
I installed a new battery, which is now charging, and the MacBook runs perfectly on battery power alone. However, I noticed some strange power draw behavior: When turning on the MacBook for the first time after reconnecting the battery, it pulls up to 3.2A, then the charger resets/drops out. It tries again, pulling up to 2.5A, resets again, and finally settles at a steady 1.0A to charge the battery.
Since it identifies the charger but only pulls a reduced, throttled current, I suspect the issue might be caused by a faulty current sensing circuit.
Since I haven't been able to find the schematics and boardview for this specific board (820-3662-03) online, could anyone point me in the right direction? Any advice on where to start measuring or how to locate the current sensing issue on this board would be highly appreciated.
Thanks in advance for your help!
Best regards,Tim
Best regards,Tim
