Failed attempt to fix faulty MacBook Pro motherboard.
There is a constant power cycle 0V->5V->19V.
The following was noted and the actions taken:
* There was a short circuit on line PP1V85_S2_IPD so components ut101 and ut102 were replaced. This fix solved the short problem.
* When the power cycle reaches 19V, there is a short on PPVBAT_AON_CHGR_REG for a second and the power falls back to 0V and cycles again.
* PP5V_S2_MAIN also shorts to ground during the power cycle (multimeter short test shows that a short circuit comes and goes). U5700 was replaced but the issue persists.
* Q5420 was also replaced.
The attached video shows the power cycle sequence.
