MOTHERBOARD REPAIR ATTEMPT
Bazel
Failed attempt to fix faulty MacBook Pro motherboard.
There is a constant power cycle 0V->5V->19V.
The following was noted and the actions taken:
* There was a short circuit on line PP1V85_S2_IPD so components ut101 and ut102 were replaced. This fix solved the short problem.
* When the power cycle reaches 19V, there is a short on PPVBAT_AON_CHGR_REG for a second and the power falls back to 0V and cycles again.
* PP5V_S2_MAIN also shorts to ground during the power cycle (multimeter short test shows that a short circuit comes and goes). U5700 was replaced but the issue persists.
* Q5420 was also replaced.
The attached video shows the power cycle sequence.
I'm not sure if I correctly understood, please clarify.
Do you check in diode mode (or ohm scale) with power applied on the board???
Also tell us the motherboard code.
So your problem is on PPBUS_AON side; resolder the fuses.
Check diode mode to ground at 3V8_AON and PPBUS_AON.
I supposed you've got stable voltage at C5250.
Check diode mode on all other secondary power rails; like 3V3/5V_S2, etc...
Also check at U8100 and U7700 LDOs; pages 41 & 37.
BTW, any reason to quote an entire post, visible few centimeters above?
Please maintain forum aesthetic...
