msi ge62 6qd ms-16j5 ram issue
i recently purchased a this msi ge62 laptop as a dead laptop for a good price.
the laptop would post, just boots to a black screen and hangs, it did seem to bootloop, but stayed on black screen.
upon inspection i found it would work with one ram in, upon further inspection i found it was the bottom ram slot that had the issue.
i cleaned both slots and both ram sticks, then it booted.
but once i got into windows it started playing up and froze.
i cleaned the bottom slot a second time, had the same result, accept this time i found the laptop screen would go off if i slightly twisted the board and flash back on when twisted the other way.
when not using the affected slot the laptop works perfectly.
i have attached a pdf of the schematic's for your convenience.
thanks
Try first resoldering affected RAM slot.
Problem could be caused by broken traces, or solders under CPU.
If DDR4 test card available, use it to locate bad lines.
Schematic, where???
