No backlight / Display 820-3787 after wrong LCD installed
Tony Tone
Q7706 pins 3&4 have 11V.
U7701 pin 11 has 11V
No output on Q7706 Change Q7706?
D7701(1) 0.851 D7701(2) 1.140
C7717 0V
Ignore backlight, we need display first. What voltage is on either side of L8300? Is LCD_PWR_EN present going into U8300?
Q7706 is related to backlight circuit. Backlight circuit is irrelevant until we have image. First image; THEN backlight!!
You do not replace Q7706 if it is not being told to open. Q7706 is P channel mosfet, so usually it will let power through when the voltage on the GATE(pin 3) is lower than the voltage on the source(pin 4) by a significant enough margin.
If the voltage on pins 3 and 4 are the same, there will be no output. Q7706 is doing its job, so you don't replace it!
R7701/R7702 create a voltage divider that U7701 allows a path to ground if it is told that backlight should be on. U7701 is not allowing Q7706 to pass voltage through because the machine doesn't think the LCD is connected/coming on.. so fix that first. Answer my above questions.
Damn. Lost a learning opportunity. Customer is jumping up and down and wants their MacBook right now. So I'll give it to em.
I know people are dumb asses. Masaratti dealer, snobbish. As far as I know, I don't think anyone else in town does board work. Gave him back just the bottom half of his Mac back. I'm not handing over my screen. LOL. Fuck but anyways. Ya I studied your videos for like 9 hours and tested, & tested to the best of my knowledge. I was also thinking as you are pointing out, but clueless. Thought I'd question Q7706 just because I wasn't getting voltage out even though I seen your explanation in videos. I will study what you have given me fa' sheezy : D Wish I still had that fucking board. Fuck the customer and their money I want to fix that fucking board LOL.
Know what'd be DAF? If we put a deposit down on a board & only you know whats wrong with it & we tried to figure it out. Like different levels. Lemme get an easy one, LOL. & then ship them back to you. Not for pay or work, but as a learning tool. A computer class I once took the back wall was stacked with computers that the teacher sabotaged and we had to pick a random one and fix it.
